TwoWatt
- Nov 4, 2001
- 249
So I notice a squealing noise last week while pulling my pull to the lake. The hub was extremely hot. So I think well, maybe the bearings are going. So I pull the wheel & hub on the left side, the inner bearings have disentegrated. So I put it on a jack stand & proceed to the right side, this was even worse, There was no inner bearing left (guess I should of noticed the angle the wheel was sitting at). <br />Now I have two axles, both with inner races that don't want to come off. <br />1st off, is there a simple way to remove them?<br />2nd: If I do manage to get them off, do I need to do anything with the spindle? Is it ok? It looks ok. But will the hub seat ok? <br />3rd: Assuming I've gone this far, I assume my best bet would be to buy new hubs - prefit with bearings?? <br /><br />Let this go out as a warning when buying a boat & the owner says, "Oh I recently repacked the bearings" that you should check them. (I did have the dust cover off when I put on bearing buddies, the outside bearings looked fine, so I assumed the insides were greased, how wrong I was)<br /><br />Thanks for any help & suggestions. I think I can rule out "take it too someone" as I don't think the trailer is moving anytime soon.<br /><br /><br />edit: If it matters, it's a single axle trailer, no brakes.<br /><br /><br />As usual. I search after a post & I found this.... Is this a better option? <br /><br />
You might consider replacing the axle assembly with a standard axle/hub assembly with straight spindles. It may be much less costly than trying to repair an older unit. The axle is bolted on the springs with two U bolts. If you measure the distance between the springs and know the gross weight of the trailer, you can get a replacement unit with new hubs. A generic 72 inch (between springs) 2000lb axle with new hubs for 5 bolt wheels cost me $72 at the local trailer supply store.<br /><br />If you don't do that sort of thing yourself, I'm sure your local boat dealer or even the corner service station could change the four U bolts and put your wheels on in less than an hour.<br /><br />Good Luck<br /><br />Roger
