Re: Stuck Allen screw in Volvo outdrive propeller cone
chris, the valve paste helps the screw driver or in this case the allen key to grip the screw, kind of works like a rubber glove when your trying to grip a jar lid i guess!<br /><br />jasco, do you think the prop actually moved on the shaft or could the (1/8th inch) just be end float in the shaft, if it moved on the shaft than knock it back on and keep working it, if its moved on the shaft even just that 1/8th inch than thats a good sign, keep working it and it should come off, not sure about a puller, I have never had to use one.
