Stuck 87 40hp lower unit
sinkingfast77
I am trying to get the lower unit off this motor but like many other posters I am unable to. I know it is the drive shaft that is holding me on but I am not sure of where to disconnect it at the top. I have read past forums and went on youtube and have not found anything useful.
rcxdm40
It connects under the bottom carb. Follow your shift linkage and you will see it. It's easier to remove the bottom cowling to access the linkage screw.
sinkingfast77
For whatever reason this is not letting me up load the pictures. My engine does not have a setup like what is shown above. There is a nut that is behind the carburetor but it is extremely difficult to get to. And to answer your question jakedawg yes the lower unit did drop a little bit
rcxdm40
Going to have to see some pics to help you. Use photobucket and copy the img and paste in forum
juno pierrat
yes its hard to get to, note in pic ,lower cowling dropped down, and starter off
bonz_d
On the 1987 40,50hp engines the setup is different than the older motors. On the left hand side there is a small clevis pin. Pull the pin and the rod slides towards the starter motor and then the shift shaft is free. No bolts to remove.
bonz_d
This is a 1987 50hp Johnson. The silver pin in the linkage needs to be removed and then the rod sides away from you. All done.
