Struggling to remove lower unit on Evinrude 30hp
Jezza668
Hey guys, I've watched a ton of videos on this removal but am having an incredibly painful time On all the videos the bolt attached to the shaft seems to slide off, mine will not budge and I cannot remove the lower unit without doing so.
The nut im referring to is the right on the photo
flyingscott
Slide the nut up the shaft to reveal a plastic keeper. You may have to scrape the paint off of the shaft but it will go. Take the plastic keeper off with a pick or small screwdriver. The keeper is slotted and will come off.
Jezza668
There was a keeper under the sleeve on the left side of the photo that I had removed, is there supposed to be 2 keepers ?
Jezza668
Mateee, there was 2 sleeves, turns out I had removed the wrong one the entire time, legend!
flyingscott
Yes there are 2 keepers, You leave the bottom keeper and nut on. The upper screw has it's own keeper ,take it and the nut off and the shift shaft will slide through the water pump housing
