The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
I stripped the threads on the grease drain hole on the lower unit of my Evinrude 150. I didn't tighten the screw very tight but the screw would not tighten. Does anyone know of a quick fix? Is there an oversize screw plug available?
A service center can put in a helicoil for around $75. They will drill out the drain and insert a threaded plug. They should pressure check for you and make sure it holds about 12psi (I think). <br /><br />Good luck.
