I have acquired new gears for the above and had no trouble removing the worn gear on the driving shft ( handle end ). Problem is the driven gear is mounted in the portion of the handle attached to the engine and when you try and drive the roll pin out the whole assembly moves and absorbs the force required to move the pin. Is there a proprietery dolly or will I need to build one.
