My 1980 holiday 181 motor mount wood blocks are rotting. The bolts through the motor mount brackets go through the wood blocks, through the stringers and there’s 4 layers of 1/2” plywood inside the stringers. Does anyone know if the mount bolts are lags going into the plywood or if the plywood is drilled and regular bolts and nuts were used?
