I'm working with a friend on a '69 Century Cheetah 16' with a Chrysler 318, Borg Warner Velvet Drive 1:1 transmission, stock prop (13x15). He just got it.<br /><br />The boat starts, idles, and revs great in neutral. The moment it goes into gear it starts to struggle. The engine bogs and then there is what sounds like valve clatter through the entire power band. Top speed is only about 2000-2500 RPMs. Oil is fresh. Electronic ignition, timing recently set. Tranny fluid doesn't look terrible, though probably could use a change. It is frothy after use. Doesn't shift as smoothly as my '84 Mastercraft Powerslot. <br /><br />The problem gets worse as the boat warms up.<br /><br />Any thoughts?<br /><br />Thanks in advance!
