Not sure if this is a problem or not. I have a 1988 125HP force.S/N 1254X88C. Last year I ran the motor w/no indications of any problems. At the end of the season last year just before storing the boat, I replaced the impeller. Tested w/hose hooked up and appeared to pump more water out of exhaust, however, I noticed that number one plug (top one) had what appeared to be a few very small droplets of water on it. Checked compression. 1-105, 2-115, 3-125, 4-125. Replaced head gasket, no change in symptoms. Compression and water droplets the same. Over the winter, I took the motor apart. Had block and head milled just enough to true up head sealing surfaces. Put new piston rings in, gapped them to factory specs. Also checked cylinders for cracks etc. All looked well. Put it back together and checked compression. 150 LBS on all four cylinders. Fired it up yesterday for the first time. I still see what appears to be a few very small water droplets on the top plug. I've not had a chance to take it out on the water yet. I'm kind of concerned. Any ideas? Maybe if I can pick Frank Acampora's brain. I've also replaced the exhaust cover gasket twice w/ no affect.
