Re: Straightening a bent frame
Anything can be straightened and/or repaired with enough time and knowledge. Try a different auto body shop, I'm sure you'll find one hungry for some business who might want to take it on. But the cost of repairs may exceed what this trailer is worth.<br /><br />Most trailers are made out of either u-channel or rectangular mild steel, and in very standard dimensions that's easy to find...so I guess if it were me I'd just cut the damaged section out and weld a new section in before I paid someone to try to straighten it. Heating is a bad idea, it changes the molecular structure and will definitely create a weak spot. Not a big deal if it's well reinforced, though. I'd just butt weld (maybe stagger the joint) a new section in and maybe try to add a reinforcing sleeve at the weld...especially if it's just a u-channel you can hide any reinforcement inside the channel. Of course I own a MIG welder, so it'd be cheap and easy for me to do it for myself.
