Stove operation
ericcarr2000
Ensign
Ok I have a 90 sundancer that gas a standard drove in it. Can someone explain to me how to operate the thing? All I know is it's an alcohol stove.
alldodge
All of them operate pretty much the same, here is a dual burner manual which also includes maintenance procedures
http://www.catalina27.org/Clips/PRICESS ALCOHOL STOVES.pdf
Go figure, have one also but have never lit it, only used it one time on the generator just to see if it worked
ericcarr2000
Ensign
No Title
This is what mine looks like.
redneck joe
Be carefull thats a pressure one it different i almost set boat on fire. Let me find the instructions on how to start
redneck joe
99 percent sure yes been a few years and only used a couple times. Look underneath should see the tank below it.
The previous he a t is the critical thing otherwise flames shoot very high. I can personally vouch that water works to put out flames
bruceb58
I hate those stoves. We replaced ours with a non pressurized type and never looked back.
gm280
I have never used an alcohol stove. But it looks and sounds like a regular Colman stove that you can use either Colman fuel or even regular gas in them. They too have to be pressurized and the fuel delivery does pass by the actual flame source to keep it pressurized so it will atomize the gas. However, you can easily see the flame from a Colman stove. I can understand that alcohol flames can't be seen. I have made little camping soda can alcohol stoves and it does heat without a visual flame. So be careful when using such fuel....
bruceb58
Wish they worked as well as a Coleman stove! Not very much heat and a pain to light and maintain!
