Re: Storing my Stingray 180RX for the Winter in Kansas
As long as the motor and drive are properly winterized, and you have an effective cover, you should be alright. Although it is always better to store indoors, as long as you have a cover and support system that will shed the rain and snow and not let it get to the interior, you should be fine. Many on here build a frame system to support the cover and provide pitch to the cover in order to help shed the rain and snow...pvc pipe is common and relatively inexpensive and simple. Just remember the basics, too, which is store it bow up, drive down, with the plug out just in case your cover fails. Check on it often.
I can understand your argument about the value equation, but a modern car or truck is much more suitable to be exposed to the elements than a boat. The fact that a boat sits unused for months is bad enough, I wouldn't compound that with exposure to weather. If you're concerned about value, I would argue that a boat stored outdoors for the winter would stand to potentially lose more value than an automobile. It's a personal judgment call in the end.
In summary: It's not ideal, but it is do-able, without substantial problems, if done correctly.
Good luck with whatever you decide.
