stopped peeing water
catchingmore
well i got a new lower unit hooked it all up and fired her up started to pump water was happy then it stopped wat could have made it stop put a new impeller on it to
D
DJ
Guest
Re: stopped peeing water
Your telltale line may just be plugged with debris.<br /><br />Unhook both ends and blow through it. Sometimes you have to clean out the discharge end with a paper clip.
catchingmore
what do you mean the discharge end ?where is that located on a 1966 40 hp rude manual shift
D
DJ
Guest
Well. since I didn't know it was a 1966, forget everything I said. You do not have a "telltale".<br /><br />Time to drop the lower unit again. If the old pump was missing some pieces, they are probably up in the engine somewhere.
catchingmore
no pieces missing i had a electric shift and went to manual shift hooked it all up was pumping water in the baral and then it stopped
BoatBuoy
Hung thermostat? I think that year had one.
