bob johnson
- Feb 25, 2009
- 4,306
hello guys...beyond my starter motor issues I have a stop circuit issue of sorts
The last time I used the motor..it was hard to start, but i got it running and used it for half a day restaring at least 4 or 5 times....then while running the motor died...that happens often until i am running a long while because of the length of my gas line...I have to pump the bulb to keep the gas pressure up...if I ran for 5 minutes i would be good once I got a solid colum of gas the whole system( 12 feet or more)...so i didnt think much when the motor died.
it usually started right back up!!
but this day it wasnt...but finally it did.
then it died..then a long time no start..then I got it going....all in about a 1/2 mile then it finally died, never to be restarted...
at the time I didnt know if it was fuel issues getting worse..or my starter issue from the battery going weak from being used so much.
today I did some tests
found there was no spark to the wires!!
(all tests are per manual for V4 models)
I did the stop circuit test per the manual....and when i pulled the packard connector off the power pack the motor got spark!!
ok so it says to go onto the ohmeter test-key switch
luckily I have the adapter PN 437270 the book says to use!!!
I went through the steps all the way to step 5
5 says: If step 4 key ON reading is a low one( it was) disconnect harness black/yellow leads from key switch "M" terminal
ok "leads" was spelled with an "S" on the end..as if there are more than one???
I only see one wire that is black/yellow on my switch
so I remove that wire from the key switch
book says:
* if meter shows a high reading test key switch. Refer to electrical section
* if meter shows a low reading, go to step 6
my test showed a low reading
step 6 reads:
Seperate the emergency stop switch lead from the harness black/yellow lead at the key switch:
me again: isnt that exactly what i just did in step 5????????????????????
what is the black/yellow wire going into the key switch if it isnt partt of the HARNESS???
I cant see how step 5 and 6 are any different!!!!
what is the emergency stop switch lead that is connected to the black/yellow lead at the key switch??
is there a connection that JUMPS into that SINGLE BLACK/YELLOW WIRE AFTER IT LEAVES THE KEY SWITCH????
TOTALLY LOST HERE
when they talk about disconecting a lead at the "M: terminal...thats the KEY SWITCH!! right??
how many things have an M terminal
actually there are two "M" terminals on my key switch but only ONE has a black/yellow wire.
next how do I test the emergency stop switch???
Thought thats what i was doing anyway
I do have an extra key switch from a back up control, i could use
by the way both controls i have ar POST 1996
I have an adapter inline to connect to my pre 96 motor
hope to hear from someone
BOB
book says:
step 6 reads:
TOTALLY LOST HERE
BOB
