Stone in tire
bookes
Came home from fishing yesterday,next door guy said I had bad bearing,removed the wheel and the rattle is inside the tire,will that cause problems?how would it get there
SlowlySinking
Master Chief Petty Officer
Re: Stone in tire
Hi bookes, have you ever used one of those aerosol cans of Fix-A-Flat in that tire? They generally leave balls of extra rubber like sealer which sounds like marbles rolling around as you so slow, they also make it near impossible to balance the tire since they move around. Good luck. :)
