? stock prop
dannysmith
i have a 1976 25hp evinrude can anyone tell me what the correct size and pitch prop should be on it?
steelespike
Re: ? stock prop
The correct size selection for your motor would depend on the boat your using.
If it is typical of what you would expect to put a 25 on the stock prop should work.
if the boat is especially heavy or you carry a lot of weight the selection would likely be different.
If exceptionally light another change may be in order.
