Hi all,
I'm planning to by a boat but found myself torn between two choices - a 2003 Stingray 200CS or a 2001 Mariah 218 Shabah. The Stingray's weight is approx 2800 lb and powered by a 4.3 MPI Merc whereas the Mariah is around 3400 lb and powered by a 5.0 EFI Merc. Both of them are approximately the same size, although the Mariah is a bit (some 600lb) heavier and has a much higher freeboard. Typically the waters here are rather choppy...so I guess a higher freeboard plus heavier boat would be a smoother and safer choice? As I dont really have any experience with either of the brands boats or with their construction I would be really interested in opinions and experiences with them.
Which one of them is a better in terms of build quality? Leaving aside the cosmetics and interior details, which of them has a better, longer lasting hull construction, a better or more reliable "back-bone" to work with? Is there wood involved in either of them (in stringers and transom)? And finally, providing the conditions are the same, what would be the fuel consumption difference when "modest cruising on plane"?
Any help appreciated!
