Got this thing a few weeks back. It would start and idle but would only run for maybe 10-15 seconds and then jerk and die. So, figured the carbs needed cleaning as it sat for several years. Im not very mechanical but am going to try doing all this myself.
Today got out there and decided to try to help it a little while waiting for my carb kits to get here next week. So, I took the breather box off and took the bowls off both carbs. They both had gunk in them. I used Berrymans carb cleaner and sprayed it up into the carb while it was still on the motor with the bowl off to try and clean what I could. I did this to both carbs. Put the bowls back on and the breather back on. Thinking it would run a little better. Now, I cant get it to run at all..GRRRR.... It will turn over and bubble a little. I reved it up a bit and did get it to idle high for about 20 seconds before it dies and now its will just grumble a little every once and awhile while turning over. Not sure what I did. Hopefully nothing too bad.
I did go buy a compression gauge today and the compression on both cylinders was 150. I know its good that they are the same but not sure if its too high or what. Like I said, Im not very mechanical.
So, I guess now I must wait for my carb kits to completely rebuild the carbs and replace the water pump.
I just hate spending a day working on something and it end up in worse shape than when you started. Very discouraging.
