5150abf
- Aug 12, 2007
- 5,808
1981 Rude 50
I am totally baffled here, went through some more stuff, changed a few more wires that were in ? shape, ran it today, ran like a scalded dog for 100yrds,on plane and almost 30MPH then dropped back to 1800RPM again.
Took the carb cover off the front and shined my spot light into the throat at WOT and it has a really heavy fog so I don't think it is high speed jets, has the correct timing low( 2BTDC) and high(22BTDC) and it advances as it should, nothing wrong with the lnkage ect. ect. I have pretty much ruled out a fuel problem.
Another clue, I replaced the fuses with breakers and one of them was shorted against the engine housing,standard marine breaker with 2 blades, forgot to tape it up, it would have been the small black wire from the engine wiring harnesss coming from the binacle,whether this happened before or after it started screwwing up i don't know but if that fried something what would it have fried???
What electrical could be bad but still allow the engine to start, idle and run up to a certain speed.
I am utterly clueless.
Thank you in advance.
