J Headrick
Thread starter- Joined
- Jan 20, 2003
- 43
still having problems starting it....disconnect the fuel line will start..after it airs out a little. holding open the elec. choke starting goes faster. reconnect fuel bad idle then dies. try to go into full throttle it dies. i took the carb apart again, cleaned let soak, lots of grime in bottom of bucket this time, blew it out...a few bigger pieces came out..new plugs, new fuel line, checked for air leaks, tightened all hose clamps...made sure none of them were pinching fuel line, rebuilt carb the works...adjusted low speed mixture screw..cleaned screen on fuel pump, did test on it, found no leaks, seems almost as though it is still flooding, quite a bit of oily gas coming out of exaust...although not as much as the first time. could the fuel pump be somehow pumping too much into the carbs...should i now go to possible electrical probs. removed flywheel also....everything under seemed like brand new. points were barely dirty...
