Still nothing 70hp
jaybrown
Banned
So ive tried eveything i can think of, I have spark, gas, and compresion but it still wont start, i will take any advice right about now
Serial # / year really should be posted !------------If this is a newer motor have you checked the flywheel key ?------Wires from switch box going to the correct coils ?----Pushing in the key while cranking it over ?----Enricher checked and working properly ?
jaybrown
Banned
when i put the flywheel on there is a fixed keyway on the shaft and i put the flywheel on with the key way in place
jaybrown
Banned
Anyone????????????????????????????????????????? how about nyine know how to set the timing??????????????????????????????????????
jaybrown
Banned
All these boaters and nobody nows nothing? thouht this was a forum for help not secret keepers?????????
MH Hawker
well jay if you want instant results then take it to a shop and pay for it, you have had several responses from people who know a lot about merc motors, take a step back and actually check things, your missing some thing, if a motor has compression spark and timing it runs
i start trouble shooting by seeing if the plugs spark when cranked, then put a bit of fuel mix directly in the cylinder and then crank, if it dosnt fire then its in the timing
jaybrown
Banned
Yes it in the timing, do you know where iam supposed to set it at? I dont have a manual and i thought this forum was for people who didnt want to spend money on taking it to a shop?!?!?!?!?!?!?!?!?!?
MH Hawker
your very wrong jay, buy a manual, boating isnt cheep and it never will be, if your looking for cheep take up golf
flyingscott
Did you check anything you were told, STAY AWAY FROM THE TIMING you do not know anywhere near enough to play with that. A lttle effort on your part is required more than just typing into the computer.
jaybrown
Banned
I have swaped out stator, trigger, coils, rectifier, power box, I got spark and compresion and i have squirted gas in all 3 cylinders and it still wont start
