still no tach.???
baitfish
79' evinrude 55hp. tried to hook up tach. but wouldn't work?? thought rectifier was bad.. so replaced it.... still no tach.?????? any ideas??? thanks, Alex.....
Hooty
Re: still no tach.???
If your tach is Teleflex, here's how it wires in. Set the selector switch on the back on "6". Teleflex Wiring <br /><br />c/6<br /><br />Hooty
baitfish
HOOTY, THANKS,.....but i already did that. it will zero out when turned on, but won't do anything else!???? :(
Hooty
Ok. Try setting the switch on the back at "5". I just looked at the chart and it depends which alternator you have. Here's the chart.<br /><br /> Application Chart <br /><br />g'luck & c/6<br /><br />Hooty
baitfish
HOOTY, I TRIED EVERY POSITION! :rolleyes: BUT NOTHING WORKS?? :confused: MAYBE STATER OR POWER PACK????? :confused: DON'T KNOW ??GONNA TAVE TO TAKE TO THE SHOP, I GUESS........ :(
