I have a mercruiser 3.0 4cylinder engine. I am not getting any spark from coil to dist cap, or to plugs, or at points. I am in desperate need of help if anyone can help me
Check to make sure that kill switch is not causing the problem, make sure that its in neutral.. Shift it back and forth a couple of times and back to neutral... Other than that maybe the key switch, solenoid wire may have come loose... Just trying to give some help out....
