still getting water into my shift lever. 86 alpha drive
lime4x4
Working on a 86 alpha out drive. I removed the outdrive for winter storage.Once again i've found water in the shift lever area. I replaced the shift lever bushings, shift cable and bellows over the summer. There was no water in the drive shaft area so i don't think it's leaking from the shift shaft area.
