Re: still fighting bogging 86 140 rude
Hi Okam,
Still fighting the bog battle here too. Off for a week vacation tomorrow, so I'm hoping to find a solution while I"m there.
In my experience, the tubes are likely different heights because they have deteriorated at different speeds (ie. one has gotten shorter faster than another). The additives to gas eat away at those tubes. Mine were so brittle they literally crumbled as I touched them. After much searching and some help from Dhadley, I tracked down a marine engine shop in Port Charlotte, Florida that I could get replacements from. The tubes are just a pressure fit, so you can pull them out and insert the new ones.
I'm going to try using a toothpick to block the intermediate jet and see what happens. Not expecting a cure, but it will be interesting to see what happens. Theoritically it should flood and kill the engine. If the bog still persists I'm back to looking somewhere other than the carbs for the solution.
Good luck with yours. If I find and answer while I'm on vacation, I'll put a post up with your name on it.
Cheers.
Brew
