Hello Everybody!
Is there someone here who knows what?s the difference is between the Stiletto Advantage and the Turbo 1 propellers? Some say it?s the same prop but why does Precision Propellers in that case have two brands for the same prop. Sounds strange. Some say it?s a bit more "thechnology" in the Turbo prop but exactly what is that technology in that case. Find it all a bit confusing, especially since they often are priced the same.
Thing is I just bought a Stiletto in a 17" pitch and it gave me a little low WOT-rpm, 300-400 rpms lower than what i expected. A 15" would probably give me a too high rpm if slip and speed is consistent. But if the Turbo generally gives lower rpms in the same pitch as the Stiletto it could be a way of limiting the rpm-drop with a 15".
