250Gimp
- Jul 13, 2007
- 145
Hi All
The controls for a '99 Force 75 are very stiff to work.
When shifting from neutral to forward or reverse it shifts very smoothly and then the control moves forward quite a ways very easily, without increasing throttle, and then things stiffen up. Once you get to the point of revving the engine it takes a lot of force to advance the throttle from idle up to WOT. Stiff enough that you have to put your elbow up in the air and lean on the throttle control. Revese is very similar, and even the idle/throttle increase tab while in neutral is very stiff to raise.
I am wondering if this is a cable problem or if it is a control that is way out of adjustment?
If anyone has any ideas I would really apreciate the help.
Cheers
CP
Cheers
CP
