Volvo Penta 260 has a sticking or bent valve. Engine hasn't been ran in several months. I found a bent pushrod on # 4 cylinder, valve was found closed. Valve will now open but spring does not re-close valve. I have been lubricating valve stem & will try to free it up. If not, heads will be removed. Has anyone else had this problem? With this engine, is it possible for piston to hit the valve?
