Quadrajet secondary air valves are sticking open. I haven't had the boat out on the water yet, but when i push them open with my finger, they catch in the open position and don't close. (not the butterflies below, just the air valves)
If I understand correctly, these air valves help meter the air flow to the primaries while the secondaries are closed, so under load if they get stuck open and I throttle back, will the engine will run poorly?
Any Q-Jet gurus out there seen this problem before?, I searched but the only post I saw was 10 years old and not much help. Is it an easy fix, or easy places to look for the binding? I've tried spraying carb cleaner on all the hinge spots. btw-the spring that helps the secondaries close works fine, up until you open the secondaries all the way and they bind on something.
Engine-Twin 1987 Mercruiser 260hp 350 Thunderbolt IV mated to Alpha One outdrives.
