Sterndrive propellers
APP
Hi,
I would like to ask experts, what would be normally the largest diameter of sterndrive engine propellers. It seems manufacturers have rather reduced size diameters.
Thanks
Best Regards
APP
Bob_VT
Re: Sterndrive propellers
Welcome.
It depends on the outdrive. What are you trying to accomplish and with which outdrive and motor set up?
steelespike
I've seen 16" diameter intended for alpa one outdrives.
Diameter is a secondary consideration and simply follows the pitch and application.
Typically as pitch goes up diameter goes down and as pitch goes down diameter
goes up.There are exceptions.
Tell us what you would like to do?
APP
Thanks to all. It has to do with a diesel sterndrive (inboard) for a rather heavy catamaran 60 ft and 25000 Lbs each hull. It seems that a sterndrive cannot be used in such a cat as it would require large diameter propeller to move on (engine 300-380 HP) and sterndrives have limited diameters.
Best Regards
APP
Ayuh,... You keep using the term "Sterndrive" as a generic term, 'n it's anything but...
There are Many different "Sterndrives", by Several manufacturers...
APP
Sorry. What I meant is this kind of sterndrive (example) : http://www.yanmar.com.au/marine/lp_series/lpseries.htm
This kind of engines Yanmar, Volvo, etc. seems they have standard propeller diameters that apparently are good mainly for light boats. The question is if there are any manufacturers with larger custom made propellers for such a kind of diesel sterndrive engines?
Regards
APP
PS: If my question is irrelevant please cancel this Thread.
Ayuh,... How big a Ship are We talkin',..??
I think you're putting way to much emphasis in prop Diameter....
Those twin prop drives move Very large boats...
APP
OK. Thanks. I will check with manufacturers.
