stern light problem
7068652873
nav lights work fine, the stern light will not work with the nav lights or by its self. its has push button resets - can't find any wiring problems - what i have read explains that switch has a diode if that is bad does it kill all function for the stern light - thanks for your help in advance
seabob4
Re: stern light problem
The diode is there to stop current flow from the lower terminal (your stern light) to the upper terminal (your nav lights). If the diode fails, you'll have current flowing either direction, in other words, your nav and stern lights will be on regardless of switch position.
Have you checked to see if your bulb is simply burned out?
