surveyor1951
- Sep 12, 2012
- 30
I retreived my boat late yesterday afternoon. My motor info is:
Engine=Mercury SN=0f758732 3.0L LX Alpha One
Mercruiser-SN=0f651546
Transom SN=0f651546
Today I drained the oil, pulled the spark plugs,blew air into the block through the spark plugs holes, then sprayed fogging oil down the cylinders. Blew out the carb with air then sprayed fogging oil into it. Cleaned the distributor (used air compressor)then sprayed white lith. grease around it & used a electrical spray for the contacts. Air blew all the spark plug & coil wires & sprayed the wires with electrical spray. I pulled the alternator off to air dry it. I put new oil in the engine. I tried turning the crank by hand put had to put a screw driver in the slots to turn it. I would have like to turn it over a few times to get the oil moving around the cylinders (not running though). I need to get a new battery & a pump to siphon the gas tank tomorrow. Then I will try to crank it over a few times to get the oil circulated.
Before I actually try to start it up, is there any other steps I should take. I would like to run it for 1/2 hour just to evaporate any moisture left in the engine block. Then change the oil again before I put it away for winter. I'll have to put methanol in the gas tank too, just to get rid of the moisture.
Any other steps or things to do? Any help would be much apprieciated. Thanks
Transom SN=0f651546
