ajgraz
- Mar 1, 2010
- 1,858
Before remounting my 1979 Merc 70, I'm recalling that the steering cable ram had a tendency to stick in the steering tube if left unattended for a month or more, and that greasy, mucky crud would come out the open (port) end and stain my splashwell.
I've cleaned out and rehoned the steering tube with a dremel extension and flapwheel, and there are no dents in the tube or issues with the steering cable or ram that I can see. I think my problems basically stem from water getting into the open (port) end of the steering tube, and either washing out or hardening up the lube.
I've already established that my steering tube has 7/8"-14 threads, and there are a good 8 or 10 threads showing on each side (outside the locknuts). I see there are products out there that are supposed to thread onto the tube end and fix these issues:
Teleflex "cable guard" SA39329 (plastic?, about $12, available on iboats):
http://www.teleflexmarine.com/marketing-material/cable-guard-instruction-manual/
Seachoice "steering guard" 28251 (stainless, about $27, also on iboats):
http://www.seachoice.com/productdetail/ProdDetail-28024.asp
Steersman (can be gotten in aluminum for ~$20 or stainless for ~$30, av. on mfgr website):
http://www.steersman.com/index.html
Has anyone used any of these products? Did they fix these issues for you?
Not getting aluminum because I'm in salt, but is there any reason to spring for stainless over plastic? Any difference between the "Steersman" and the "Seachoice" ones?
