Re: steering troubles
All good solutions, But an easier tip to try is to loosen the tension nut at the end of the steering shaft. If this doesn't do the trick first then you are stuck with the other options. Turn the nut counter clockwise to loosen the tension, I would recommend about 4 complete turns. Try the steering and see if it has the feel you are looking for, then try it on the water. Not at full throttle, but about half, until I had it adjusted to where it felt better. Keep in mind that you don't want it too loose.
