Steering problems
A.J. Winters
I have a 1994 Astro bass boat,with a 125 Mercury,, Over the pass weekend i went out in boat, The steering was very hard to turn, The last time i used it it was fine no problems, The boat sat up about 3 weeks, can anyone help, Thanks
ufm82
Master Chief Petty Officer
Re: Steering problems
Actually had this happen to me. I had taken my boat to Florida for a week's vacation and spent a good deal of time in the Gulf. Rinsed everything (or so I thought) before heading back to the house each time after dunking. Drove home and never gave it another thought.
Two weeks later I tow down to the river to do a little catfishing. Back the trailer down, unhook the boat and launch. (I'm normally by myself.) Park the truck and jump in the boat. Fire the engine up and find that not only is the steering stiff, it's frozen completely! Despite my manly efforts to break it loose, I could not. Believe me, loading a boat on a trailer in a river with current is NO fun with no steering. I was wet, hot and PO'd by the time I got her back on dry land.
The saltwater had corroded the steering cable end in the tilt tube so badly in just two weeks that it was not going to move without some attention. And like many other boats out there, I had to take the engine off the transom to remove the cable end from the tube. There was a 1" spot right in the center of the tube where the ebd had welded itself to the inside of the tube. I wound up cutting the end of the cable off, punching it out with drift and hammer and repalcing the whole thing with a hydraulic system.
If you can get the cable end out of the tube, clean the inside thoroughly and grease well. Do the same to the cable end. If the corrosion has gotten into the sheath it's time for a new cable. Once you repair/replace the cable, make sure you keep it greased so it won't happen again.
UFM82
A.J. Winters
Thanks for your help, I can move the steering it does move it was just very hard, I grease it and will try again this weekend Thanks again
A.J. Winters
I want to thank you for your help I took the sterring apart and clean everything put it back together and grease it good works great thanks again
dan4081
After you have gone to all the trouble of removing the cable, cleaning out the tilt tube and greasing everything well, you might want to consider installing a boot over the telescopic ram to help keep the water out. I really like mine. Available at the iboats.com online store:
http://www.iboats.com/Steering-Cable-Boot/dm/*******.528723521--**********.098007427--view_id.39716
Very interesting, but....how exactly does it work?
Where do you attach it to?
Thanks!
Stachi
I gotta get me one of those ! ... it looks like a boot for an inner tie rod on a rack and pinion steering on a car........priced about the same...
Stachi
Thanks!
When installed properly , it keeps water and dust off of the cable... because the boot is bellow shaped, it will nicely extend and retract , while covering the part of your steering cable that is fully extended...and when it is fully retracted.The section of the cable when it is fully extended is what brings nasty stuff like salt , inside of the sheath when retracted. I hope this helps...
Stachi
Thanks!
the large end gets attached to the O.D. of the outer oart of the cable, the smaller end is attached to the very end of the cable....
