Re: Steering problems
you have to pull the pump// sorry been there several times/// and the plastic probably broke off and you will need to get that broken part out also, then if you didn't loose the snap retainers all you need is to go buy another of those crappy pieces of plastic and you will be fine till it breaks again, you can slide a piece of rubber hose and a flat washer on the cable once you get it loose but you need to pull the cable through the transom first,,, place a snug piece of automotive hose over the outer cable and then a stainless flat washer and place the cable through the transom, once you have reinstalled all the parts you push the hose and the flat washer up against the inside of the transom and put a small stainless clamp on the hose piece to keep it from sliding, then you may avoid breaking the plastic piece in the future as it will secure the cable from the inside and keep it from pushing so hard on the plastic fitting. I hate those things and if you don't remove the ski from the water when they break you will take on water through the loose cable, I have had the same problem with the reverse cable fitting, since the plastic is getting a lot of stress holding the cable in all by itself.
