Hi,<br />Everytime I go out to work on this new (used) boat I find something else is wrong...<br /><br />Ive got a 3.0L mercruiser with a teleflex rack and pinion steering.<br /><br />My steering is really stiff. The more I work it with the wheel back and forth, the better it gets, but if I let it sit for a minute I'm back to where I started. Ive changed a cable before, so first I figured that if I freed up the outdrive, I could see if its the cable or not. Only problem is that the conncection where cable goes to outdrive is rusted up pretty good. Any ideas, suggestions?<br /><br />Also, I cant seem to get the steering wheel off. I removed the cap, then the bolt and washer, then I cant figure it out. I pulled, but it wouldnt come off?
