Re: steering lock on 91 johnson 90hp?
Thanks, Dhadley. Makes sense to me, and wouldn't cost much.<br /><br />I had a message string a few weeks ago about this motor. I still have a question about the tach setup for this motor. The tach (brand unknown) only displays properly at idle when the selector is in the 12pole position. Does this make sense for this motor?<br /><br />I've fixed some air leaks in the fuel line and am up to 5000rpm at WOT with a 13.25x17 prop on a 18ft vhull Tracker. A little short of where I should be, but I want to eliminate the tach as a possible source of misinformation before working on more rpm.
