First trip out on the ocean with my new (old) Pursuit 26' Console Cabin w/twin Evinrude 175s. Could have been worse, but came back on one engine. The end of the linkage rod between the engines for the steering rusted out and broke off so I was unable to steer the port engine. What is this part called??? It's like a connecting rod of some type with bearings on both end. It looks like the bearing part would unscrew to replace it.
Also, the port engine temp runs much higher than the starboard engine. It reached about 200 once, but the "HOT" light did not come on. All the lights come on during the start up so I know the light works. Water is coming out, but takes about 10 seconds after cold start to start flowing.
Another issue, the boat just had new cables and the throttle controller replaced. It takes a lot of force to push the throttles off idle, then it moves easier. It this an adjustment or does something need to be lubed?
Thanks!!!
Thanks!!!
