Re: Steering isues 2001 Bayliner Capri 1950
Ayuh,... Did you pull the clevis pin on the other side,..??
The corrosion is usually Inside the aluminum tube...
If it's Clear,.. Does the drive swing easily with it disconnected,..??
If so,... Replace the cable, 'n helm...
