Steering issues.
Oldshakey2
I have a 1997 bayliner trophy 1703 with a 1989 force 125 (Us Marine). I just replaced the teleflex cable and the outboard is still hard to turn. I have no kinks in the cable. It turns easier once past straight. But to return to straight is a chore.
Ayuh,.... Welcome Aboard,..... Does the motor swivel easily when the cable is unhooked from it,..??
Does the swivel tube have grease fittin's on it,..??
Did ya grease 'em,..??
Oldshakey2
Yes. It appears to be the motor that is taught. Super smooth with the tiller arm disconnected. I routinely grease everything once a month when I check the grease in my trailer Berrings. Since it's a new cable I put a solid coat of water disbursing lithium on the new cable. And keep the outboard and all the electronic components with a good coat of boeshiled.
alldodge
Cable is free but motor is tight, your going to need to remove the motor if it does not have a grease fitting, which I don't think it does. The pivot pin needs greased and your probably need to take it apart to get at it. Suggest asking the question in the Chrysler/Force section to see if those guys have an easier way to do it
