divedigger
- Apr 27, 2008
- 4
I have a 1962 starcraft that was orginally a cabin crusier. I wanted more of a fishing boat with high sides for the deep mountian lakes in my area and when the kids were small, they could run around inside with a life jacket of course and not worry about gettint to close to the edge and falling overboard. I took the cabin top off and more or less made what looks like the stripper or muskie boats from the north. I built a deck up front and put pedstals for side by side fishing or just a single in the center then made a console and mounted in the center for plenty of room. Later I made a heavy dive ladder and mounted on the port side to make entry and exit for scuba diving. We have plenty of room for a couple of divers and tanks and the ladies lay in the sun topside. I built the boat out of necessity and lack of money, but she has done well for about 15yrs now. Now to get to the point, under full power steering response is great, but when coming in to the dock or more so loading on the drive-on trailer at slow speed, the steering response time is the worst I have ever dealt with on several boats I have had. When lining up to load you get going straight then may need a little correction to hit the trailer dead on but the boat does not react quick enough and most times you reverse and start over. It is a 18ft with a shallow draft semi-v bottom and I have even considered somthing midway on the keel like on the big ski boats thinking it may respond quicker. I have had a 70hp all the way up to the 115hp now, it has always steered the same at idle speeds. Most boats you do not even have a steering control issue but this is my first. I know the bottom is fairly flat but I have had jon boats with up to a 70hp with no problem. Does anybody else have or notice this at slow speed or have any ideas or thoughts on what to do? Most anybody that can drive a car can drive a boat on a trailer easy, but this thing is a hand full, always has! Sorry for being long winded but looking for a solution. Thanks Divedigger
