steering cable
sergioy
I have a friend that owns a 94 Stratos with a 175 hp Johnson on the back. His steering is extrememly stiff, to the point of being scary. I aske dhim why he doesn't jsut lubricate it, and he said nothing would fit the niple on that line. <br /><br />Does this year boat need a special adapter to lube the sterring cable? Or does he need to replace the cable?
Re: steering cable
He needs to disconnect the motor from the cable to verify that it's the Cable,+ Not the swivel tube on the outboard...........<br /><br />If it Is the cable,........ Replace it....... For a "Marine" part, they're Cheap......
sergioy
Re: steering cable
Thank you Bondo for your advise, I will let him know ASAP.
Trent
Re: steering cable
I agree with Bondo...<br />But they do make this to lub the cable.
