dbm_nj
- Mar 22, 2009
- 29
I want to replace the steering cable but can't figure out how to remove it - so I hope you guys can answer a few questions.
1. If I remove the Steering Link Rod and undo the Cable Nut I am still not able to pull the steering cable out. I assume the cable is to move to the left as shown by my yellow line. Correct?
2. Do I have to remove the 2 Grease Seal Cap Nuts (my words - and only 1 can be seen in this photo), and what happens when I do remove them? (i.e. grease gets all over everything, parts fall out, etc...)
3. The other end of the steering cable is enclosed in my steering wheel box under the dash. There is a warning embossed on the box warning that opening the box might cause a loss of steering. Do I open it? And how is the cable attached inside?
I have been told that I need to remove the cable in order to see the length stamped on it - then I can order a new one.
This procedure shouldn't be difficult - but my first attempt left me confused.
Your help and suggestions would be greatly appreciated.
