Got a 1976 merc 650 thunderbolt and i have a steering arm question.
Got the motor from a guy that had it on an old 50 - 60s runabout with the old style double cables and pulleys for steering
Put the motor on my 89 15' thundercraft. I cleaned out the pivot tube via drill and rotating steel brush. Greased it up pretty good and the steering cable went through and attached smoothly.
My question is that i hooked up a 12" steering arm and i can steer hard right just fine but not hard left
If i take the steering arm off the motor move effortlessly side to side.. hard right and left no sweat.
i also noticed that the cowl is rubbing on the arm. Not enough clearance. How do i go about finding the right steering arm for this motor . I would think that it can be used with my steering set up since i can attach it to the motor just fine
