Re: Stator Voltage Test?
Using a standard Multimeter is not gonna work... And measuring at the battery isn't either, due to the AC charge releasde from the battery itself.. What you want to measure (obviously) is AC voltage from the stator leads... You really need a Volt Meter with Peak Reading Capabilities on AC.<br /><br />You can buy an adaptor (that may go with your multimeter) that will allow you to run this test.<br /><br />You can go ahead and try it without the adaptor, as I don't think the voltage going to the rectifier will be enough to fry it. But it may jump all over the place so much that you'll never get a constant reading....
