Re: Stator unit symptoms
You should hwve 2 wires comming from stator to termials on power pack , termial #4 and 5. color of wire is 1 brown wire and 1 brown with orange tracer( orange may look yellow from age) but wires come from same spot on stator. Disconnect the 2 wires from powerpack and connect red meter lead on 1 wire and black meter lead on the other wire, at cranking rpms with spark plugs in using peaking reading meter you should have app 150 volts. Next red lead to brown wire, black lead to ground, other wire not touching anything, meter should read 0. If you get reading here wire or stator is shorted to ground. The charge coil is not grounded.
