I think I just bought myself a new "spare" stator, grr...<br /><br />Problem is getting no spark on all 4.<br /><br />I have diligently searched and I cannot find the post that I _thought_ I had read that told me to test resistance from Brown/Yellow to ground and from Brown to ground. These readings are infinite resistance.<br /><br />I am now reading (I think) that I should have been testing Brown/Yellow to Brown (all stator leads disconnected) and getting around 750 Ohms.<br /><br />If this is the correct test, then my old stator is fine, as is my new stator :-/ and I still have not identified my no spark problem. Yellow to Yellow test out on both around 1 Ohm, which seems to be correct.<br /><br />PLEASE, someone, confirm for me the correct test of this stator, my ding-blasted Seloc manual does not even mention the stator ohm test, and just says to check output with a neon tester, which seems to be an extinct tool. I don't have a peak reading voltage meter though I think I will have to get one soon...<br /><br />Thanks y'all...<br /><br />Jason
