EDIT: I got the instructions emailed to me.....disregard.
I'm replacing the stator on my '92 Force 150. This engine has the "Thunderbolt" ignition, which had that big square "converter box". The stator I have is meant to eliminate that box, but I have no idea on the wiring change, and can't find any directions anywhere.
It's a CDI stator, with two yellow wires, one blue, and one black. The yellow wires go to the junction point for the regulator/rectifier. The blue, I connected to the blue wire from the switchbox. The black, I connected to the black from the switchbox, and from there to ground.
I'm left with 2 wires.
First, a red wire, from the starter relay, which originally was bolted to the converter box, which is no longer there. It has no place to go to now.
Second, I have a Violet/white (purple w/ white stripe), that is coming out of the switchbox, with nowhere to go now, since the converter is gone.
I want to believe that power to the switchbox is via that violet/white wire, and that I should connect the red wire to this one, but I'm not sure.
Has anybody dealt with this yet? I see this thing sold on several sites, but no directions. I've got my Clymer with me, but the circuits aren't identified as to function.
Thanks.
Thanks.
