Re: Stator leaking? 1973 85HP Johnson
OK, went out and removed the stator again, squinted and grimaced and can't see any obvious cracking, no green goo on the stator itself either.<br /><br />There is, on the outside of the stator ring at each charging coil, what looks like about 1/2 inch of the edge of each charging coil just peeking through the surface, but no goo trail.<br /><br />Perhaps previous owner replaced and re-blew the stator due to not changing the failed rectifier, unfortunately I am not able to contact him since he apparently gave up in frustration and had a towing company come and take the boat away, which in turn sold it to this intrepid backyard mechanic for the proverbial song...<br /><br />Guess it's time to order a new stator (based on the ohm test results), cross the fingers and hope I don't have to call that towing company myself! ;-)<br /><br />Thanks all for the info, any last thoughts appreciated, I'll be sure and post a followup on resolution (hopefully) when I have the new stator installed.<br /><br />Jason
